Doing the LT1 carb conversion was the best thing I ever did for my car.
Old Nov 15, 2003 | 11:05 AM
  #16
JoeliusZ28's Avatar
Originally posted by aintno6
I personally love carbed motors, for different reasons. I love when ever you ride in a old muscle car, and you can smell the fuel fumes coming right off that carb, and the whole sound of the car is different.
Nothing beats the 'sucking' sound of a wide open four-barrel
Old Jan 6, 2004 | 06:53 PM
  #17
hairbear's Avatar
Originally posted by neil350
What happened with the opti spark?
Yeah what he asked
Old Jan 6, 2004 | 08:14 PM
  #18
aram's Avatar
Originally posted by ProCharged95
Maybe I've taken a step back in technology but I've taken a step forward in performance.
did you use a crank trigger or cut the cowl for a regular distributor? Have any pics.. for a non blower/turbo drag car I think that carb is the way to go.
Old Jan 6, 2004 | 08:15 PM
  #19
aram's Avatar
Originally posted by hairbear
Yeah what he asked
you can just disconnect it I assume or i think gm has a block off plate.
Old Jan 6, 2004 | 09:20 PM
  #20
neat's Avatar
I think carburation is the way to go, IMO. Nothing quite like being able to adjust the A/F ratio with a .79 cent screwdriver instead of hundreds of dollars worth of computer equipment.
And the sound a 4 barrel makes at WOT is priceless.
Old Jan 6, 2004 | 10:02 PM
  #21
RacinLT1's Avatar
im going with a 1200cfm 4 barrel throttle body. on a single plane intake with dfi. should "sound" interesting if i can hear it over the exhuast and solid roller.
glad you are happy with the car,you did what you felt was right.
Old Jan 6, 2004 | 10:35 PM
  #22
MauriSSio's Avatar
simplicity is the KEY!!!DOWN with the smog *****!!!!!!! Carb uses a little more fuel but were talking at a miniscule scale (not a big difference between between rich and lean). The mileage lost will mostly be due to going wit a 3 sp. tranny.
Old Jan 6, 2004 | 11:47 PM
  #23
n20ta2's Avatar
I have both fuel injected and carbed cars And their both fun to drive in totally different ways. I love the throttle responce of my T/A And I love the brutality of my high 9 sec Regal. Witch one would I rather tune? The regal hands down , carbs are easier to tune for max hp period.But as far as going to the track for an easy night of racing thats the T/A s teritory I can show up and even as the temperature drops through the night I dont have to pop the hood for one second where as with my regal I would be reaching for my jet case. Getting the t/a to that point has been frustrating and expensive so for that reason I see where he is coming from and for that reason carbs will be around for a long time.
Old Jan 7, 2004 | 08:02 AM
  #24
Jeff H's Avatar
Well, the carb may have been the quick fix, but there are guys running the same times with the stock computer and similar mods so I don't think you really made much progress. The biggest issue you're going to run into is that most of the nation is changing to tougher emissions standards and it's illegal to run a carb on a FI vehicle on the street. You will eventually have to go back to FI or be stuck driving the car at the track only. You could also be fined or even have your vehicle taken away from you. So in the effort to save money and make things easier, it may cost you a lot more in the end. If you want to drive a carbed vehicle, buy a 60's or 70's car. Sorry, not trying to be harsh or anything, but the reality is that things are getting tougher.
Old Jan 7, 2004 | 08:38 AM
  #25
Heatmaker's Avatar
Advanced Member
Is that a joke...? I see guys with 5.0's dropping the Carb motors in them like nothing...emissions no problem...never heard that stuff before.
Old Jan 7, 2004 | 10:20 AM
  #26
Mike383LT1's Avatar
carb conversion
would like to see some pics i do agree with the others i think it is a step back but if it works for you go with it not to mention the coolness of having something different
Old Jan 7, 2004 | 11:27 AM
  #27
fireman's Avatar
I am considering doing this as well. I don't drive my car everyday, it just sits in the garage most of the time. I've been through 4 optis in the last 10k, tuning is a friggin nightmare, I've had 2 mailorder tunes and a dyno tuner that after a month gave me my car back and my money and said "I'm not working on it anymore, good luck.".
Old Jan 7, 2004 | 11:33 AM
  #28
FireAm94's Avatar
One point everyone is forgetting is that while carb motors make more peak horsepower...peak isn't what matters. It's so easy to adjust other areas in the powerband on a fuel injected motor.....unlike a carb setup. The fuel injected cars of the same horsepower as a carb setup will always be faster.
Joe
Old Jan 7, 2004 | 03:26 PM
  #29
Jeff H's Avatar
Yup, these enhanced emissions tests are coming to an area near you soon. NJ will soon be checking your OBDII computer to see if there is any programming done to disable emissions controls as well. Going to a carb will get you fined and possible loss of vehicle. People who removed their cat's will be required to put them back as well. If you removed your smog pump, you will fail the visual for it not being there.
Old Jan 7, 2004 | 03:29 PM
  #30
FireAm94's Avatar
Sure am glad I live in Alabama hehe. No checks whatsoever.
Joe
