doing LE2heads GM847..can I start my car on stock tune..
Old Feb 8, 2006 | 06:04 PM
TransAm396's Avatar
ok well like the title says..im going to be doing the heads/cam install over the next 3 weeks..when its all done...can i start my car to make sure it runs right on the stock tune? maybe drive it down the street? i wont be beating on it cuz of the stock injectors and fuel pump...but I want to at least be able to start it. im going to get a madZtune and 30#ers and a fuel pump but like i said..i want to at least be able to close the engine up..valve covers and valve lash..
Old Feb 8, 2006 | 06:15 PM
97bowtie's Avatar
Re: doing LE2heads GM847..can I start my car on stock tune..
Yes, you can start it up, adjust valve lash etc., but I wouldn't drive around too much w/out any way to monitor how the car is running.
Old Feb 10, 2006 | 02:38 PM
madwolf's Avatar
You can start it, but you will need to help it with the gas pedal if you want it to stay running. Make sure it's on stock injectors not on the 30s though.
Old Feb 10, 2006 | 05:21 PM
TransAm396's Avatar
ok....now if i were to send you the PCM...how does this work? how long? how much to tune for the heads cam?how do i fine tune after the initial tune? lol what info do you need...
Old Feb 10, 2006 | 05:22 PM
TransAm396's Avatar
ok wait im going to check out your madtuner.com..didnt see that till now
jj71787
Dec 30, 2014 02:15 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
teedoff59
Aug 8, 2002 01:36 AM
