Doing cam swap with engine in, walk me through plz(or link to guide)
The subject says it all folks. I've already started taking apart the car, but not too far along because all the parts are not hear yet. I'm going to pull the heads off to swap them too because one of them is warped. I know the waterpump, opti, timing chain and radiator have to come out. I was wondering if the A/C condenser has to come out? Also, I know I have to jack the motor up for the cam to clear some stuff, but how exactly does it need to be lifted and how much?
Thanks John |
You dont have to remove the condensor,just tilt it out of the way.And no you dont have to lift the motor.Do a search for street illusions racing.They have a great install guide.
What joeSS97 said. Here are a few pics from my cam/heads change out. You can move the cond. out of the way without crimping the lines if you are careful. Also the hood latch needs to be removed to get the cam out. No need to jack the motor.
http://community.webshots.com/photo/...66237512rBUovR http://community.webshots.com/photo/...66237707RuYnnB Good luck Jeff D. |
Thanks for the help guys! The links were very helpful:)
Originally posted by PoorMan What joeSS97 said. Here are a few pics from my cam/heads change out. You can move the cond. out of the way without crimping the lines if you are careful. Also the hood latch needs to be removed to get the cam out. No need to jack the motor. http://community.webshots.com/photo/...66237512rBUovR http://community.webshots.com/photo/...66237707RuYnnB Good luck Jeff D. |
That's cause some peoples cams are longer than others. PUN :D
Jeff D |
