does water pump come with?
i'm having a shop put a new water pump in cause during dyno time they said the water pump blew out. i forgot to tell them to make sure to reinstall the 160stat into the new water pump. now does a new water pump come with a thermostat? if not then i don't need to remind him bout the 160 stat.
Re: does water pump come with?
A new GM pump comes with a 180° thermostat installed. I'd call the shop about saving the 160, but if they put in a remanufactured pump, they probably already traded yours in for the core.
they didn't take the waterpump out yet so i told them. shoebox- off subject question,i swear since i replaced the heater core in my 95 grandam that my blower blows stronger out of the vents. air only goes through the heater core when you use heat or defrost-correct?
It could be that your old core was dirty and was slightly blocking the air or your new core is just more free-flowing.
Blood type Z28
Apr 8, 2015 11:34 PM
