CamaroZ28.Com Message Board
-   -   Does this sound right (oil change ?) (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/does-sound-right-oil-change-478570/)
reamo04 Oct 14, 2006 10:36 PM
Well, last night i was hanging out with a few friends (couple of them work at mechanic shops). When i started my car, they heard a wonderful ticking that we believe is either piston slapping, or a lifter. One of the guys (has a LT1 in his s10), said that he has heard that if you add 1 qt. tranny fluid when u do ur oil change (1 qt. tranny fluid, 4 qts. oil), that it will take the ticking away since tranny oil does not foam.
Has anybody else heard this? Are there any negatives to this?
v8pwrdz28 Oct 14, 2006 10:55 PM
Re: Does this sound right (oil change ?)
i have heard of it but i would not do it. have u checked all your rockers to make sure the lash it set right?
lt11997 Oct 14, 2006 11:09 PM
Alot of people do it if they have a sticking lifter and the tranny fluid usually cures it.
Josh'95Z28conv Oct 14, 2006 11:16 PM
The tranny fluid is high in detergents, and cleans any gunk that may cause a sticking lifter. Some people use diesel fuel. Or you can go buy an oil additive thats made to be added to an engine.
StripedFomula Oct 14, 2006 11:24 PM
would that be used for a short period of time, or would you run it the entire 3k miles?
reamo04 Oct 15, 2006 01:13 AM
Im also kind of curious about that question.
shoebox Oct 15, 2006 08:17 AM
Personally, I wouldn't do it on anything but an old junker engine I did not care about and as a last resort...but that's just me.
Cook Performance Oct 15, 2006 08:49 AM
puuting one quart of tranny fluid in with 4 or 5 quarts of motor oil will not hurt a thing, it will help in cleaning out the sludge buildup in the crankcase and all the oil passages. Run it for 1,000 miles or so and then run Mobile one Synthetic.
FlamingChicken Oct 15, 2006 10:35 AM
usually i would only run 1/2 qt if I was gonna leave it in there. atf also breaks up a lot of carbon. been bringing rotaries back to life for a long time using the atf trick
