do you need the A/C bracket to delete ac?
Old Dec 8, 2003 | 07:41 PM
1994TransAm's Avatar
do you need the ac bracket to delete AC?
i have 2 motors both have the A/C delete bracket. i need new wires so i got some taylor universal wires with opti ends and i wanna run them long and and down close to the block.
(got the idea from taner at MID-MICHIGAN)
question is, can i just remove the A/C bracket i have and get a shorter belt? i think it would work right?
otherwise i'm gonna cut a 2 inch hold in the A/C bracket and run wires through it!!!!!!
anyone got a comment?
Old Dec 8, 2003 | 07:47 PM
SVT Killer LV's Avatar
theres no reason to drill anything. You can run aftermarket wires easily there.
But to answer your question, on the 1LE pulley you need the ac bracket because that is what the pulley attaches to. Its a little tricky but you'll get all the wires in there...
Old Dec 8, 2003 | 10:13 PM
revtime's Avatar
I ran my wires through there without cutting holes in anything.
Put some convoluted tubing over the wires to keep them from getting chafed and your good to go.
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
magman
Apr 15, 2016 03:08 AM
War Engine
Sep 18, 2015 07:28 PM
WPHIG2
Aug 27, 2015 06:37 AM
