CamaroZ28.Com Message Board
-   -   Do I need this?? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/do-i-need-160147/)
dnz28 Aug 19, 2003 03:37 PM
Do I need this??
I want to remove the condenser (radator in front of actual radator) and I am wondering if I take it out and have the a/c by pass it will the a/c still work. I know it wont work as well but will it work.
Fastbird93 Aug 19, 2003 04:11 PM
Something tells me no. As in no the A/C won't work. I can't say for sure, but the condensor is there for a reason.
Injuneer Aug 19, 2003 04:15 PM
You have to remove the heat from the circulating, vaporized freon. That is the job of the condensor. It removes the "heat of vaporization" and the gas condenses into a liquid, so it can flow to the evaporator, and absorb heat when it evaporates. No condensor = no heat removal.
dnz28 Aug 19, 2003 04:15 PM
I thought it was just there to cool the freion
