different timing chain req. for elec. WP?
Old Oct 19, 2004 | 08:15 PM
dmoor88's Avatar
I know that you'd need an elec. WP if you went with a Cloyes double roller or something comparable, but can you run an elec. WP on a stock timing chain?
Old Oct 19, 2004 | 08:18 PM
trans9_5am's Avatar
Re: different timing chain req. for elec. WP?
Of course you can. You can either leave the old WP gear in there or take it out and plug it with a freeze plug.
Brandon
Old Oct 19, 2004 | 08:25 PM
dmoor88's Avatar
plus i found this, explaining the install of a mezeire EWP.
http://www.projecttransam.com/projects9.asp
will the CSI be similar aside from having to work the housing over in order for it to fit?
Old Oct 19, 2004 | 08:30 PM
trans9_5am's Avatar
The difference is that for the CSI you have to grind out 4 "humps" to the housing in order for it to fit but the body of the pump is narrower than the Meziere. For it, you have to break a decent amount of fins off the fan shroud to get it to work. I prefer the CSI especially if you have the housing already off. I just used a dremel and one of the sanding bits, it was VERY simple. But everyone has there own opinions.
Brandon
Old Oct 19, 2004 | 08:32 PM
dmoor88's Avatar
yeah im definitely going with a CSI WP. I just talked to a buddy who installed a Mezeire and he told me the wiring was a bit confusing. Any pointers?
Old Oct 19, 2004 | 09:00 PM
trans9_5am's Avatar
Have an awesome relay schematic but cant find it. It also incorporated a switch inside the car for use at the track in the staging lanes in between passes. If i find it ill send it to you. Search this site as im certain i found it here somewhere.
Brandon
Old Oct 19, 2004 | 09:04 PM
dmoor88's Avatar
sweet. let me know if you come across it.
another question. will it be easier to run the wiring off a water temp gauge NOW since ill be down there or is it still pretty easy to do once everything is installed?
Old Oct 19, 2004 | 09:22 PM
trans9_5am's Avatar
Off a water temg gauge??? You want the pump to run all the time while the engine is running. Have you done a search on this site for wiring elec. WP's? Do that first and if you have any Q's let me know.
Brandon
Old Oct 19, 2004 | 09:54 PM
dmoor88's Avatar
yeah i want it to run all the time but I also want to be able to keep an eye on the water temperature itself via a gauge ran to the interior.
Old Oct 19, 2004 | 10:24 PM
trans9_5am's Avatar
The only way i know you can run a temg gauge is through the pass side head. You can not hack into the temp gauges that the PCM reads because they use resistances and this will interfere with the gauge readings. If you know some other way, let me know.
Brandon
Old Oct 19, 2004 | 10:44 PM
5.7LT1Formula's Avatar
when you do the Electric WP install do yourself a favor and spend $40.00 for a pump kit from Painless wiring...it is simple to hook up and will be extra assurance that you do not burn up your pump and end up frying your motor..
Old Oct 19, 2004 | 10:46 PM
dmoor88's Avatar
how is it extra assurance?
Old Oct 19, 2004 | 11:15 PM
trans9_5am's Avatar
My opinion on that is
Brandon
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
