CamaroZ28.Com Message Board
-   -   Difference in starters??? Help!! (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/difference-starters-help-569375/)
mitchntx Jan 5, 2008 09:16 PM
I bought a starter a while back to have as a spare or use on a future race car. Today, I decided to put it on my new motor.
To my surprise, the bolts bottomed out before the starter was tight.
Upon inspection, the mounting base was about 3/8" shorter than the other starter I had. Everything else is identical.
What gives? Were there different starters for different years? Maybe Auto vs 6 speed?
Green96Z Jan 6, 2008 01:46 AM
Auto and manual use the same starter for the LT1, which is what I assume you have since you didn't post any vehicle info...
Maybe you got a starter for a V6?
SS RRR Jan 6, 2008 03:39 AM
Is the starter from a dealer or a parts store? Most any parts store will sell you a starter for a traditional SBC which may require shimming to work.
mitchntx Jan 6, 2008 05:03 AM
Thanks for the replies ...
The starter was bought in a lot of "LT1" parts I bid on, probably a year ago or more. It isn't new.
