CamaroZ28.Com Message Board
-   -   Difference between lash and preload (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/difference-between-lash-preload-367934/)
tardy007 May 17, 2005 09:43 AM
I know this is a dumb question but they seem to be the same from what I have been reading in here. I am trying to get no preload & 0-.005 lash I plan on turning the pushrod until I get resistance and then another 1/8 (max) turn on my 7/16 stud. Is this right for no preload and ~.005 lash?
Thanks in advance
shoebox May 17, 2005 11:08 AM
Re: Difference between lash and preload
Lash is the amount of space between the rocker arm tip and the valve stem. Preload is the amount of compression added to the hydraulic lifter after zero lash.
BLinindoll May 17, 2005 11:24 AM
If you want no preload then you wouldn't be turning it 1/8th of a turn. If you are turning it 1/8th turn past 0 lash, then you will have 1/8th of a turn of preload.
tardy007 May 17, 2005 11:27 AM
Thanks guys.
That is what I thought, so it didn't make sense to have no preload & 0-.005 lash. Wonder why I was told to set it at that :confused:
