CamaroZ28.Com Message Board
-   -   difference between a I-H beam rod (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/difference-between-i-h-beam-rod-478010/)
94_camm Oct 11, 2006 06:38 PM
How can you tell the difference between I-H beam rods?
Dave89IROC Oct 11, 2006 06:42 PM
Re: difference between a I-H beam rod
I beam and H beam, look at the letters, I beam is wide at the top and bottom, h beam is wide on the sides
94_camm Oct 11, 2006 06:58 PM
can u tell which wat these are?
http://i36.photobucket.com/albums/e4...er1/383002.jpg
seawolf06 Oct 11, 2006 07:12 PM
Those are H-beam rods.
Dave89IROC Oct 11, 2006 07:33 PM
yup, wide on the sides
seawolf06 Oct 11, 2006 07:42 PM
Wouldn't that actually be the front and back since they face the front and back of the engine?:D
bowtiepwr Oct 11, 2006 07:54 PM
Originally Posted by 94_camm
>is that a Cloyes True Roller timing chain? so your going with an electric water pump?
quickSS Oct 12, 2006 01:00 AM
On this page are some good photos showing I beams and H-beams. And also lower down on that page it shows which ones have block and cam clearance "built" in, (compares big end shapes).
http://www.karl-ellwein.org/EllweinE...ingrodpage.htm
Karl
rskrause Oct 12, 2006 07:26 AM
As far as functional differences go, either cross section works fine if it's a good rod appropriately selected. The "S" shape rod or the "two piece" rod is to be avoided at all costs though!!
http://images.google.com/images?q=tb.../40_conrod.jpg
http://www.motorkars.com/images/spec...ting%20Rod.jpg
Rich
SS RRR Oct 12, 2006 07:56 AM
Rich
Is that a sample of your collection of expensive broken parts? :D
Sweetred95ta Oct 12, 2006 08:45 AM
I can tell what everything is here, but WTH is that blue bottle thingy? Vacuum canister? Do you always buy a bunch of new expensive parts that need to stay clean and then set them on the concrete outside? ;)
rskrause Oct 12, 2006 09:04 AM
You are a cruel man:death: :p
Rich
Bersaglieri Oct 12, 2006 09:40 AM
Rich
I think its your opti.
No seriously though nice work.
-Dustin-
Daniel6718 Oct 12, 2006 09:40 AM
is there a purpose for the differant rods? is 1 stronger? i hear h beams are better?
JakeRobb Oct 12, 2006 09:40 AM
Hehe... I've got a pic like that... I'll have to dig it up.
