CamaroZ28.Com Message Board
-   -   Difference between AC Delco, Delphi and Cardone Opti? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/difference-between-ac-delco-delphi-cardone-opti-695265/)
vmatt350 Jun 23, 2009 08:49 PM
Just as the title says, what is the difference between the three?
Here is what I know:
From Advance Auto the Cardone has a life time warranty. The Delphi has a 1 year warranty and Im not sure about the AC Delco.
The Cardone cost less then $300.
The AC Delco cost over $500.
The Delphi cost between $400 and $500.
I checked with Jason Cromer and his price is about the same as the Delphi, plus shipping.
What is the difference in quality and what would be the best choice and longest lasting?
moparman Jun 23, 2009 09:14 PM
Go with the AC Delco or the Delphi. Check Rock Auto and see if their prices are any better.
93v8clone Jun 23, 2009 09:22 PM
cardoen is a cheap knockoff .ac delco is cheaper at summit
Injuneer Jun 23, 2009 10:22 PM
GM spun off a lot of their parts divisions, into an independant company called Delphi. GM kept the AC/Delco brand for some of their parts, but Delphi got most of the electronic lines. What was once AC/Delco in many electrical parts is now Delphi. Delphi managed to go into bankruptcy at least 3 years before GM did.
foxbat Jun 26, 2009 09:57 PM
delphi/ac delco = same quality
95 WHITE TRANS Jun 28, 2009 05:36 AM
Ac delco optis from summit go for 309.00.
BTC Jun 28, 2009 03:59 PM
Looks like they want 395.95 for the unvented optis.
vmatt350 Jun 30, 2009 08:48 PM
Thanks guys! Looks like I will be getting one as soon as I get back from my vacation. Im not looking forward to changing this thing. Seems like a nightmare.
BTC Jun 30, 2009 10:14 PM
Actually, it's not that bad. It's certainly no nightmare.
ssclone Jul 1, 2009 06:25 AM
screwing around i had my opti and w/p off in around an hour and half.
thepartsladi has the opti's in stock for 295 + 12 shipping.
mine willbe here in a day or two, and they are delphi.
aaron
vmatt350 Jul 1, 2009 08:27 PM
The nightmare Im afraid of is breaking a screw/bolt off in the block. Im sure if I run into anything Im not prepared to deal with I will be on this site ASAP as usual.
ssclone Jul 1, 2009 10:48 PM
its not bad at all.
if you have any doubts, spray everything down with PB blaster the night before you tear it apart.
aaron
shoebox Jul 1, 2009 11:24 PM
If you do things like you are supposed to, you won't have those kinds of problems. Do your research first.
