CamaroZ28.Com Message Board
-   -   Dies when warm (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/dies-when-warm-885409/)
kgkern01 Mar 9, 2017 08:59 PM
Dies when warm
So I have an issue with my car I'm trying to track down, and it seems to be getting a little worse. The car will die about 10-15 minutes after cold start. I've spaced out the ICM, tried a new one, tried 2 different coils, fuel pressure is fine when cranking, it just wont start back up unless it sits for a long time, and when it does start back up it dies pretty quickly afterwards again. I tried data logging it the last time it did it, I didn't see any codes thrown or saved either. I'm tired of throwing parts at it, any suggestions?
Thanks!
SBCGENII Mar 13, 2017 07:59 PM
Re: Dies when warm
If it dies when it warms up that it is probably closed loop related. Could have a bad O2 sensor or exhaust leak.
