Deleteing the ac
Deleteing the ac
If i delete the ac will i have any problems with the heater and i notice that there is a hose coming from the water pump to the ac. What do i do with that and can someone give me a quick run down on the proper way to remove it. Thank you
Heat is unaffected. That has nothing to do with the a/c system itself. The condensor, compressor and lines going to and from the HVAC box on the firewall somewhat behind the pasanger shock tower needs to go. Thats it. The hard line to the compressor was so hard to get off I just cut mine. Buy yourself a 1LE idler pulley to replace the compressor's vacant pulley location and possibly a SLIGHTLY smaller belt (some cars run the same length belt as befor a/c delete...varies from car to car) then you're done.
alex5366
Mar 8, 2015 11:32 AM
