crunched fuel return line?
for those of you that have swapped your own fuel pumps.. Is there a way that the fuel return line could get crunched or pinched during the procedure of taking down Tank to swap pumps?
Re: crunched fuel return line?
it's possible. one way that you woule be able to tell would be from a pressure test. you would be seeing higher then normal pressures
pressure is at 85 psi and I swapped the stock reg for an adjustable and it's not helping at all
where could it have gotten piched or crunched? so I know where to start look ing.
Thanks. |
| All times are GMT -5. The time now is 09:44 AM. |
