CamaroZ28.Com Message Board
-   -   crossbrace (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/crossbrace-239227/)
Zachz28 Mar 19, 2004 07:19 PM
crossbrace
In my car i have a black cross brace that goes under the exaust and driveshaft right after the cat. how important is this? and what would happen if i removed it?
PatriotTA Mar 19, 2004 07:21 PM
I can't see much happening as a result of removing it. It is just a thin piece of stamped steel - it can't do that much. I removed mine but I have a driveshaft loop in a nearby location. If its causing a clearance issue, go ahead and remove it. Otherwise, leave it on there for now. I can't see any gains (even weight loss) from removing it.
ToocoolZ28 Mar 19, 2004 08:16 PM
I took mine off 8 years ago when I replaced the exhaust. No problems in 175,000 miles.
Ron
mobleman Mar 19, 2004 08:36 PM
Mine came of 9 years ago when I put a flowmaster exhaust on.. No problems. It would be interesting to know the real reason why it was there though, (i.e. NVH, structural, safety etc..)
dnz28 Mar 19, 2004 08:54 PM
it was put there to tie the floor pans together, A little imo that weak crap would flex bad under a side load so buy a aftermarket, make your own, or take it off.
Bud M Mar 19, 2004 09:57 PM
If you look at the way its made, it is intended to keep the floor from flexing in the direction of "squeezing" the trans. tunnel. If you think it's "weak crap", take it off and try to bend it in that direction. I'll bet you can't.
GM would not have put it in there if there was not some reason for it. Why do you want to remove it? It can't be very heavy. How will your car be better without it?
dnz28 Mar 19, 2004 10:22 PM
I dont think mine will bend its made from 2'' square tube, and 1/8 plate. :D its still crap.
mobleman Mar 20, 2004 08:49 PM
Mine was actually taken off by the shop that installed the exhaust. I didn't notice till months after that it wasn't reinstalled..
Personally I'd leave it on....
Zachz28 Mar 20, 2004 11:51 PM
i want to remove it cause my exaust is hitting it
$hawn Mar 21, 2004 10:45 AM
Put a few washers under it maybe?
T/A#4 Mar 21, 2004 11:47 AM
Stronger one's are made by GMS $149. & they claim it stops body flexing.
Bud M Mar 21, 2004 11:59 AM
I would figure out how much it needs to be lowered to clear the exhaust, get a piece of aluminum that is slightly thicker and make spacers. Or if you can't do that, use washers likw $hawn said.
CamaroBoy96Z28 Mar 21, 2004 12:54 PM
I believe BMR makes a stronger version of that part too. Instead of being fairly thin, there is a metal tube spanning the trans tunnel. I still have mine in there and dont plan on removing it.
