In----credible
In----credible
The damn low oil sensor I was replacing crumbled and broke in half... Landing back in the oil pan. For the love of...
Lame. So this 2 minute job just turned into a drop the Y-pipe, spend a couple hours underneath the car that I have no room under so I can rip off the oil pan ordeal.
While the oil pan is coming off... Is there a nifty new oil pan I should be putting back on?
Re: Inf***ingcredible
I would have poured in like 3 quarts of oil and tried to flush the little peice out, but not that you have it out it doesn't matter. I see nothin wrong with the stock oil pan unless it's rusty, crushed or cracked.
But in any event, there are a couple plastic shards in there I think, because the part cracked and crumbled before my eyes as it fell in.
I don't think I could trust that they would all come out. I'd rather have the piece of mind.The center of my pan is dented in, it's not flat.
Thats why I just put a plug in and got rid of that leak prone piece of crap. If you need the computer to tell you to check your oil you probably shouldn't be driving an F-body.
LOL thanks.
I have a part #, but it's not a GM # so I don't know if it will help you. I got it from Star Auto Parts (Auto Value). The part # for this aftermarket sensor is FLS14.
The whole reason I was changing it was just because the old one was leaking like a bastard. It should have been an easy job, damnit.
I don't need it... But I don't want to look at a light on my dash either. What else did you have to do to keep the light from coming on?
Originally Posted by Z95m6
You have a part number for that? my sensor always leaks oil out of it and i wouldn't mind a new one.
Originally Posted by kick Z tail out
LOL thanks.
Re: In----credible
Yeah, I can't ever do I simplist of jobs on my car without something breaking. Tried to clean my TB, which is about a 30 seconds job. Took 3 hours because I had to remove that stupid air silencer on the elbow which was attached to the air dam or something then i couldn't get clamp around it for some reason so I ended up using zip tips and red silicone.
Re: In----credible
Originally Posted by Josh'95Z28conv
I think many people just leave them in there. Things like this is what the screne on the pick up tube is for
Re: In----credible
So you think it would be perfectly safe to leave the plastic bits floating around in my oil? I'm going to be making a nearly 3000 mile road trip to Bowling Green and back this summer.
