CamaroZ28.Com Message Board
-   -   crank position sensor (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/crank-position-sensor-166138/)
ROADRAGE Sep 5, 2003 12:18 AM
If you remove it, will the car run?
I removed mine when I did H/C swap. The computer was supposed to be programmed for 30 lb injectors, and the sensor delete. I am now wondering if it was done.
96z Sep 5, 2003 12:20 AM
Your car will run normally but throw a code.
ROADRAGE Sep 5, 2003 12:35 AM
Yep, I had a feelin, thanks for the confirmation
