Crank Hub Help Needed!
Old May 1, 2003 | 08:18 PM
Paul94Z28's Avatar
Hey-
My cam install was going pretty well until I was re-installing the crank pulley and the bolt boke off. This is the longer bolt you use to get things started before you put the oem bolt back on.
Any idea how I can get the busted bolt out of there?
Things were just going too well...
Help is always appreciated.
Thanks in advance.
Old May 1, 2003 | 08:58 PM
BOWTYDE's Avatar
Have you tried to pull the hub back off?
I would try that first and see if you can get of vise grips on it, if that dosen't work your going to have to try an easy out.
Old May 1, 2003 | 09:03 PM
Paul94Z28's Avatar
If I try and pull it off, isnt that going to jam the hub bolt in further?
Old May 1, 2003 | 09:27 PM
BOWTYDE's Avatar
Most likly not, what kind of puller are you useing? it shouldn't screw the bolt in more. if you really affarid of that then get two long (10ft) breaker bars (steel rods) and put them of each side of the hub and work it off by prying it aginst the sway bar, it well help alot if you hear the hub with a blow trouch for about a minute before you try that.
Old May 1, 2003 | 09:33 PM
Paul94Z28's Avatar
Puller
Steveo-
I have the kind that screws into the pulley in 3 spots and has the shaft that runs down to the broken bolt.
Old May 1, 2003 | 10:55 PM
BOWTYDE's Avatar
The pulled shouldn't turn that bolt in, if it feels like it is stop.
Old May 4, 2003 | 06:32 PM
Paul94Z28's Avatar
Pulley Off
The Pulley is off. Next weekend is ezout time. I will let you know how things progress.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
