cracked heads
Old Oct 24, 2009 | 07:44 PM
ghost97ta's Avatar
cracked heads
where do lt1 heads crack usually. when over heated.
i don't see any cracks on the on the surface
where the gasket goes?
Old Oct 24, 2009 | 08:10 PM
MachinistOne's Avatar
The LT1 heads are pretty crack resistant, most aluminum head cracks in the chamber are more due to detonation rather than over heating. A little line between the valve seats is the most common spot.
Old Oct 24, 2009 | 08:44 PM
Cook Performance's Avatar
The Lt1 heads are pretty tough. Get them checked out by your local machine shop any time you pull them from the engine, especially if you had an overheating condition.
Jake www.cpengines.com
Old Oct 24, 2009 | 11:34 PM
96capricemgr's Avatar
When overheated they are more likely to go soft which good shops can test for.
Old Oct 25, 2009 | 07:42 AM
NightTrain66's Avatar
they usually get soft like 96CAP mentioned. Have them Rockwall tested to be sure.
Look at the valve stem hts and see if they are all uneven also. If so, get another set of heads since these are JACKED.
When they do crack, it is usually from the very center head bolt to the water jacket that is about 1/2 away from it.
Lloyd
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jlo
Feb 3, 2015 09:41 PM
Chris Anderson
Jan 27, 2015 08:30 AM
squarehead
Nov 21, 2014 08:02 PM
