Cracked head? Broken lifter (pictures)
Old 01-15-2019, 03:38 PM
BMX Dad's Avatar
Symptoms: 1. Loss of coolant, not leaking; 2. Tappet noise.
Pulled heads. Broken lifter - intake on number 3 cylinder. Tan mineral deposits on head, valves, and piston on number one cylinder. Tan deposits only in cylinder one. No apparent issue with head gasket in that area. Thought it was a crack from coolant hole to cylinder head area. Machine shops says no crack. Divot in head allowed coolant leakage. Surfacing heads to address divot and slight warping.
Replacing all lifters - $128 insurance policy.
BMX Dad is offline
Old 01-18-2019, 07:32 PM
graham's Avatar
Re: Cracked head? Broken lifter (pictures)
You might pay a little extra attention to the threads of the #3 intake rocker arm stud.
As that lifter's pushrod cup retainer came loose it allowed the cup to turn and apparently jack up the pushrod enough to pull on the threads of the rocker arm's stud. That then pulled on the cylinder head casting and flowed coolant between the head gasket and the cylinder head creating the "ditch."
graham is offline
94 Sunburst formula
10-14-2008 08:31 PM
Loony
03-30-2007 07:49 AM
zturbo
Parts Wanted
09-10-2003 06:54 AM
Quick Reply: Cracked head? Broken lifter (pictures)
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
