could and would a bad PCV cause..
oil consumption?
I have the tell-tale dip-stick popping up issue combined with oil consumption. Just curious if it could be the PCV valve before I assume the worse (rings and/or pistons) |
it could be, but mostlikely not. they are cheap replace it and see what happens
I believe they rattle if you shake them if they are good. I would just replace anyway. My U shapped hose was cracked real bad and it was only $10-$15 for both from the dealer.
Dipstick popping up yes, oil consumption i really doubt very much. Sounds like its time for a compression and leakdown test.
yeah, that's what I figured. Just thought I might get lucky:(
actually we had a bad pcv valve on a mazda 6 i know its not an lt1 but still...it cause a lot of headaches and we finally traced it down to a 5 dollar pcv valve imo you should change it
Originally Posted by 67camaro02
(Post 4954063)
oil consumption?
If it still runs OK put an extra valve cover breather on it while ya save for new rings.
Or just leave the stick out. |
(Post 4954395)
| All times are GMT -5. The time now is 08:52 AM. |
