could and would a bad PCV cause..
oil consumption?
I have the tell-tale dip-stick popping up issue combined with oil consumption. Just curious if it could be the PCV valve before I assume the worse (rings and/or pistons)
If you do assume the worst then make sure to get a leak down performed. Blowby can be generated from the top and/or bottom end. I don't believe there would be enough pressure from normal blowby to overwhealm the breather tube. I think it's time for a leak down test.
