could i have installed my fuel filter wrong?
Old Sep 1, 2003 | 06:02 PM
meandmyz's Avatar
i didnt think there was a wrong way to do it and maybe there isnt but i dont know. I was reading another post that a guy had a hesitation problem and that came up, thats my problem too, it runs fine when i dont get on it, but when i give it gas when i am in like 4th doing 40 it bucks and stuff. maybe this is it, i dunno
Old Sep 1, 2003 | 06:22 PM
Josh'95Z28conv's Avatar
There is usually an arrow on them. Its pretty hard to miss, and put it in backwords. Dont know if it would cause a problem or not though...
Old Sep 1, 2003 | 06:25 PM
meandmyz's Avatar
i noticed that, just wondered if i had to release pressure or something
Old Sep 1, 2003 | 06:31 PM
CamaroRob97's Avatar
I've done'em b4 on a few 4th gens and they're a piece of cake! (probably one of the easiest maintainence requirements on the whole car) Unless u r getting the wrong filter it is Idiot proof, the sending side has a plastic coupler with 2 small tabs obn each side that clips in and the recieving side just screws back into the metal fuel line, 5 min job!
Hope this helps!
p.s. Prime the filter about 3-4 times to replace the lost fuel in the lines/old filter, also to releave some pressure take the gas cap off before u take off the filter
Old Sep 1, 2003 | 06:33 PM
meandmyz's Avatar
i already installed it yesterday. i didnt prime though, is that bad? could that be causing my hesitation
Old Sep 1, 2003 | 06:36 PM
You prime it by rotating your key to run and back a few times, running the fuel pump. If your car has run, the filter is primed.
Old Sep 1, 2003 | 06:39 PM
meandmyz's Avatar
ok thanks
Old Sep 1, 2003 | 10:26 PM
You can't install it wrong, since it is threaded on one end and has a quick connect on the other.
Old Sep 1, 2003 | 10:31 PM
CamaroBoy96Z28's Avatar
I did mine last week. You cant even try to put the filter on wrong.
Old Sep 2, 2003 | 12:45 AM
meandmyz's Avatar
i know its in the right way, i was wondering if i was supposed to let pressure out of the lines first or something but now i am realizing that shouldnt matter
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Deadbolt24
Jan 19, 2015 01:29 PM
30thZ4C
Dec 26, 2014 05:09 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
