CamaroZ28.Com Message Board
-   -   Corvette LT1 (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/corvette-lt1-886950/)
Camm95Z28 Oct 2, 2018 08:45 PM
Corvette LT1
I know the Corvette LT1 has 4 bolt mains but wil it fit/work in an F body?
My engine threw a rod and optikn B for me is the remanufactured Corvette LT1 from Jegs.
Chimera96 Oct 2, 2018 09:16 PM
Re: Corvette LT1
Any 94-97 LT1/4 will be direct fit in your F/body
Injuneer Oct 2, 2018 10:24 PM
Re: Corvette LT1
There are subtle differences. Other than the accessories bracket, none of these would cause the engine not to “fit”
- fuel lines connect to fuel rail on opposite side of engine
- some water pump connections point in different directions.
- Corvette engine has dual knock sensors
- oil pressure switch has more wires
- accessory bracket is different, if included
- exhaust manifolds
Courtesy of Shoebox:
http://shbox.com/1/lt1_water_pumps.jpg
Differences can be resolved by swapping external parts from your F-Body LT1.
95LT4Z28 Oct 2, 2018 10:42 PM
Re: Corvette LT1
like fred say's - swap a couple of the externals and your good to go
