Cooling issues...
Cooling issues...
... ok, recently I got the low coolant light, pulled over to check and noticed water leaking steadily from the left side of the car(opposite the intake), so I check it when I get home, and sure enough the coolant resevoir/battery tray has cracked and is leaking like crazy. So I replace it, fill the resevoir and the radiator and head off to class. After about 15-20 min of driving, the damn light comes on again! The temperature stayed at normal levels, and there was no visible leaking from looking under the car and a cursory check under the hood when I got to class. So when I got home I checked and the resevoir was low, so I filled it once the car cooled down and figured it was normal. Same thing happened again, no sign of leaking or anything. Someone help me out here, please? Thanks,
James
James
CARiD
Sep 30, 2015 05:44 AM
cmsmith
Sep 14, 2015 09:09 PM
