coolant light wont go away
Well the coolant light came on a little bit back.... everything underneith the car appears dry and the resivior is full and so is the radiator. What the hay is wrong, where is the coolant level sensor anyways. A guy I work with said its in the resivior and if you bang on it a bit it will unstick from the bottom or whatever and it went off for a day then reappeared..??????????????
Re: coolant light wont go away
I HAD SAME PROBLEM UNTIL I CHANGED THE COOLANT SENSOR ITS PRETTY EASY TO DO ITS RIGHT UNDER THE THE RADIATOR CAP ON OUTSIDE OF RADIATOR ITS ABOUT 30 DOLLARS AT AZ http://shbox.com/1/low_coolant.jpg
Just unplug the sensor and your probs. solved.
This is a common occurance with our cars so you can either unplug and try to clean it with a tooth brush and see if that helps. Or you can replace if you really think you need to. I always just unplug mine in my cars when it comes on.
wow how crappy.... Ill see if I can get it to work by cleaning or replacing if I feel the need to otherwise I guess Ill unplug it. This year its been one small irritating theing after another hard to keep up.
warmeck
Apr 16, 2015 05:50 PM
