Coolant issues....HeLp
Old Apr 12, 2006 | 11:08 AM
guyette117's Avatar
I have a 94 z28 and i have coolant leaking somewhere but cant figure it out i had a hole in the radiator and i thought that it was that but it wasnt i replaced the radiator and still seems to be leaking, i will fill it up and depending on how i drive the coolant will last like if i get on it it must **** it out or something but when it starts to over heat it gets hot then if i go let some pressure out of the radiator it goes away till it builds up again then if i put water in it its fine till it gets low again
Old Apr 12, 2006 | 11:15 AM
bstieboydp's Avatar
Re: Coolant issues....HeLp
make sure the radiator hoses are good around the seals where they meet the radiator (shouldve been replaced w. new rad. but u never know.) also check the stupid things like maybe a bleeder valve open, they are right by the thermostat, do you hear gargling when its hot, also is your car lacking power at all
Old Apr 12, 2006 | 11:20 AM
guyette117's Avatar
its not lacking power, i replaced the radiator myself and the hoses werent replaced it, there is a gargle noise there isnt much coolant in it when i does over heat
Honda Hunter's Avatar
Couldnt he just do a pressure test? Do you see a puddle or just everytime you check it it gets lower?
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
