Coolant bubbling out the overflow???
So I got the oil leak fixed and the overheating problem fixed. Everything ran fine the first two trips out with the car. Once yesterday and once today. Only one thing....
when I parked the car the first time, I could hear the coolant bubbling even though the car didn't get that hot, or so I think. I popped the hood and coolant started flowing out the overflow like a water fountain. I figured the guys just overfilled it. Today, drove the car about 30 minutes and parked it, everything was fine. Drove it another 30 minutes later on (about 30 minutes ago) and when I parked it I could hear the coolant bubbling and steam was pouring out the overflow tube. What could this be.
Any help is much appreciated. Trying to get the car together for Thunder In The City this weekend and my family reunion on Saturday.
Ben
Ben
Did the radiator get drained and refilled after the repairs? Sounds like you have an air pocket in the cooling system. The radiator cap is not the lowest part of the cooling system. Make sure you put the heater on when refilling the coolant and try to lift the front end up (ramps or jacks). I had an overheating problem after changes hoses. Radiator overflow would spew out antifreeze. Finally got the stupid air pocket out and now it's fine.
Be sure the hose for the steam pipe and the hose for the remote reservoir are not swapped on the radiator. There seems to be a rash of that going on lately.
The hose port right in the radiator neck goes to the reservoir.
I added coolant/water to the radiator and replaced the radiator cap. It actually seems to be getting worse. Still spewing out the overflow resevoir and the car is getting hot. I hope it's not a blown head gasket, as I only have about 500 miles on the current gaskets. No coolant in the oil, no oil in the coolant from what I can see. It was taking the car a while to get hot. Doesn't appear to be dripping any coolant other than whats coming out of the overflow. No white smoke out the exhaust. I ordered a new 160 thermostat to replace the current 160 stat thats in there now which only has about 15k on it. Won't be here til Tuesday.
I'm baffled.
I'm baffled.
The radiator that's in there is brand new, just put in 2 days ago. So yes, it was drained (in a sense) while the other repairs were being made. Shoebox, Do you mean the little hose that sits about a tenth of an inch from the radiator cap? Is that the one that's supposed to go to the resevoir. I'm going to go investigate and see what I can find. Also going to try to bleed the system. Wish me luck.
Could be the two small hoses that run to the top of the radiator; or just below the cap. I had mine switched and it will heat up and run out the overflow. Make sure that the hose running to the overflow is the one on top; or the first hoes below the cap.
Ok, that's what I thought he meant. Thank you. The hose closest to the top it running to the water pump and the hose about an inch below it is running to my resevoir. I will now go ahead and switch these. Can I get a confirmation that The top hose goes to the resevoir and the one an inch below it goes elsewhere?
Thanks to everyone who posted and helped.
Please stay tuned in the next 5 minutes for my next dilemma. WOT SHIFTING!
