CamaroZ28.Com Message Board
-   -   Converting two bolt main block to a fourbolt main... (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/converting-two-bolt-main-block-fourbolt-main-476115/)
taylorcrzy Oct 2, 2006 07:35 AM
Is it possible to convert the block over to a four bolt main with the motor still installed? Other than dropping down the K-member is it possible to do it? Just curious if anyone had tried to do it.
sssalah Oct 2, 2006 08:48 AM
Re: Converting two bolt main block to a fourbolt main...
Not possible. It'll need to be align bored/honed in a machine shop.
engineermike Oct 2, 2006 09:02 AM
I second that motion.
taylorcrzy Oct 3, 2006 11:20 AM
Thanks for the reply.
wrd1972 Oct 3, 2006 01:56 PM
Only if your a magician.
confused327 Oct 3, 2006 02:08 PM
why would you want to, switching from a 2 bolt to a 4 bolt doesn't really matter untill you are making a good amount of power, enough power where you would have to have the motor out to accomplish it.(excluding power adders)
shoebox Oct 3, 2006 02:35 PM
The hardest part would be trying to fit a machine shop underneath the car.
sbs Oct 3, 2006 03:25 PM
Clearly he already has that part solved, in order to do enough engine mods to require a 4-bolt in the first place...
FastLt1 Oct 3, 2006 08:33 PM
You could probably do ARP studs without removing engine and be as strong as stock 4 bolt.
bmwmcars Oct 4, 2006 09:18 AM
Not sure if this is accurate or not, but 3 machine shops have all told me that even doing studs requires line bore/hone, since it changes the clamping force applied to the caps.
FastLt1 Oct 4, 2006 07:45 PM
Best listen to them. It was just a thought. I did it on a old SBC. But didn't know about torque plates and align honing. Just wanted something harder to blow up. ;)
rskrause Oct 5, 2006 12:49 AM
That is accurate. It needs to be align honed if you install studs.
Rich
taylorcrzy Dec 20, 2006 02:53 PM
Ok, I will just build a spare block and stroke it then pull the original motor and swap everything over and reinstall the new motor. Thanks
