convertable leak... please help
i bought my car not too long ago and was hoping for a better quality vehicle than my previous pos. well everything is great about the car but one problem, it leaks. its not a bad leak just a small one on door windows, and a little where the side mirrors are. i heard that the camaro has window adjustments, is this true, could this be the problem? i was also thinking about changing the weather striping. does anyone have any info about this. thanks for the help. Its a convertable
I have a '95 convertable, and it leaks in the same spots. At the top of the window, and by the side mirrors. Its a camaro thing, I think, and not a convertable thing. I think replacing the weather stripping would take care of it, but I havnt tried yet. If there are any adjustments, I would like to know as well.
josh95, do you like the spec stage 2 clutch? i had mine replaced a few months ago and i was trying to get a good clutch but the one the put in is called stall clutch i think, i couldnt understand his accent. its a good clutch, but i wouldnt know the difference between a stock clutch and an aftermarket clutch, but does this sound like a brand, or did i misunderstand? thanks
Mine leaks alittle also at the top corner of the windshield and door in heavy rain.....Hey its a big improvement over my 65 Mustang conv.
Sometimes you just need to make sure the sides are pushed all the way out... above the windows. Give them a nudge and that may fix the problem.
| All times are GMT -5. The time now is 06:30 AM. |
