Connecting rod side to side clearance (end play) out of spec.
Old Feb 17, 2007 | 06:24 PM
wrd1972's Avatar
Just got a measuement on my new Scat forgd connecting rods end play. It is sitting at .020" between the two connecting rods.
GM spec say .015" max. on the CR end play.
How big a problem is this?
Old Feb 17, 2007 | 06:43 PM
respectirocz's Avatar
personally i dont think its a problem
i had an automotive professor who used big block chevy connecting rods in his chrysler 440 block, that gave him extreme amounts of rod clearence he still ran over 700 hp and reliable motors
just out of curiosity, pressed pins or floating pins?
Old Feb 17, 2007 | 07:41 PM
wrd1972's Avatar
Pins are floating.
I will ask the engine builder on on Monday what he thinks.
Old Feb 18, 2007 | 11:57 AM
quickSS's Avatar
the GM spec is for the stock crank/rods. That .020" is pretty normal.
Karl Ellwein
Old Feb 18, 2007 | 12:00 PM
MachinistOne's Avatar
That number is just fine.
Old Feb 18, 2007 | 10:44 PM
wrd1972's Avatar
Great, thanks all.
Old Feb 19, 2007 | 09:49 AM
chrism400's Avatar
You are perfectly fine.
Old Feb 21, 2007 | 10:03 PM
wrd1972's Avatar
I have read that the rod clearances will really affect the oil pressure.
My main bearings are .0020", rod bearings are .0025" and of course the rod clearances ar .020".
I have the Melling select 10553 pump which is standard volume and pressure, should I keep that or get the GM white spring?
Old Feb 21, 2007 | 10:19 PM
chrism400's Avatar
Below 7000 you will be just fine there too.
edman
Jan 25, 2015 02:41 PM
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
