Compression ratio
HEy whats up guys, i was wondering if anyone could tell me what the stock compression ratio of a 1994 Z28 would have been, and also what the lift and duration of the stock cam was. Also does anyone know the compression ratio of a C5 corvette. Thanks
Re: Compression ratio
Compression for Al headed LT1's is 10.5 and cam is 203/207 @ 0.05", lift is around 0.450-0.470". LS1 has slightly less compression, probably due to the reverting back to regular cooling pattern.
202/207 116LSA, 0.450I/0.460E according to the table in this article:
http://www.automotiverebuilder.com/ar/ar99928.htm There seems to be a variety of different specs quoted in different sources. The LS1 used in the C5's had a 10.1:1 CR. |
| All times are GMT -5. The time now is 08:42 AM. |
