CamaroZ28.Com Message Board
-   -   compression? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/compression-221327/)
1984camaroz28 Feb 5, 2004 01:09 PM
compression?
what would be an ideal compression to run for a 396 stroker. I wanna run 10lbs of boost what would be a good compression ratio?
rskrause Feb 5, 2004 01:36 PM
Re: compression?
Depends on the cam and the fuel. But in general ~8-8.5:1.
Maybe you should ask in the "Forced Induction" forum?
Rich Krause
