Comp-R lifters
Comp-R lifters
Ok, i was wondering if i could run stock lifters on the cc306 cam with 1.6 rockers and comp 941 springs. The info on the springs are as follows:
* Seat pressure: 135 lbs. at 1.750 in.
* Open pressure: 357 lbs. at 1.250 in.
* Coil bind: 1.130 in.
* Rate: 447
I calculated the coil bind to be at 1.75-1.13= .62" which should be plenty. At .576" lift of the exhaust, i calculated the open pressure to be 391 lbs. Would i be able to run this setup on a stock lifters, or would i have to run comp-r lifters?
* Rate: 447
well i have the cam and springs already in the car. The lifters only have 40k on them and all i will be doing will be rockers and guideplates. If i have to do lifters too, it will take alot longer. Just need to know if the stock lifters can handle that kind of spring pressure at 6500 rpm.
How would the stock lifters be on some monster dual valve springs with the stock cam? I bought the car used over a year ago, and it has some beefy dual valve springs with the stock cam, and I'm starting to get worried about collapsing a lifter.
