colder stat, engine wear down quicker?
actually, it's the heat and running an engine at hotter temps that typically causes engine wear to occur quicker. The only thing that will happen with the lower thermostat is if you dont have your fans set to come on earlier, your coolant will get moved around a lot more, might need to flush and recharge it more often. Other than that, a cooler engine = happier engine :-)
guionM
9
Aug 29, 2002 01:48 PM
