Cold Air Question?
Old Feb 15, 2004 | 10:41 PM
RedWS6TA's Avatar
Cold Air Question?
which cold air has the least amount of problems with water when it rains. i don't want to have to put my car up everytime it rains. please just give me some advice as to what cold air is the best to be driven in the rain.
Old Feb 15, 2004 | 10:43 PM
DonHood's Avatar
I wasn't aware any of them had probs in the rain.
Red96Lt1's Avatar
They are all the same as far as that is concerned.
Old Feb 15, 2004 | 10:49 PM
Vendetta's Avatar
Unless your filter(s) is/are under water, rain won't be a problem. I hear a lot of kids saying that they hate ram air lately, because it sucks up water and "blows up the engine, yo"...
Must be a little bit of a rice factor going on...
Old Feb 15, 2004 | 10:53 PM
RedWS6TA's Avatar
i was under the impression that the filter on the k&n and the moroso cia hung so low that if you went into a puddle of water that either the filter would get wet of water would be slung off of the tire and get into the air filter. the reason i ask is because the maf and water dont get along and if water is being sucked up in the filter it will work its way to the senser and that is not a good thing.
Old Feb 15, 2004 | 11:02 PM
Vendetta's Avatar
CAIs hang higher than the bottom of the body, so unless your frontend is under water, your fine. Water can be sucked in via splash, or through a Ram Air, but most of the time the H2O is just vaporized due to the heat of the motor. Nothin' to worry about there.
Old Feb 15, 2004 | 11:09 PM
RedWS6TA's Avatar
with the supercharger set up that i use to have and my buddy has the K&n and every time it would rain the water would get into the air filter and get the maf wet and the car would start to back fire and missfire. the damn ses light would just blink away. in fack my buddy sold his k&n because he was tired of having this problem. has anyone else ever had this problem or does anyone have any pics of there cold air on there car.
Old Feb 15, 2004 | 11:27 PM
Vendetta's Avatar
What brand was the supercharger kit? I have quite a few friends with F-Bodies, and I can't say I've heard of that problem before. The most info I can give you is that I never had any problems with my old SLP twin-filter CAI.
Old Feb 15, 2004 | 11:33 PM
NuMbNuTs670's Avatar
No prob with my CAI, I had to drive through a huge *** puddle of water that was about 3 inches deep at least and i was doing 65 mph and hit that **** hard( didn't notice it till the last sec since the puddle was damn long and look like part of the road at night) no probs at all and i was driving through it at 10 mph afterwards and it was a little higher then the bottom of my door.
Old Feb 15, 2004 | 11:45 PM
RedWS6TA's Avatar
mine was a powerdyne kit but i know that my buddy and i have had these problems.
Old Feb 16, 2004 | 01:58 AM
Eliminator's Avatar
I have SLP and never had any problems yet. I also try not driving it in the rain. Black car pain in the butt to keep clean
Old Feb 16, 2004 | 02:49 AM
NewbieWar's Avatar
Cold air accually grap air from closer to the ground, rather then cooling the air correct?
Old Feb 16, 2004 | 03:37 AM
ead94z28's Avatar
There is no cooling affect, per say. It just happens that where the intake sits is away from the heat of the engine area, so the air sucked in is somewhat cooler. I can't see water getting in there at all. The filter is enclosed by the lower splash guards, so unless your nose is completely under water you're ok. I've driven in some serious rain and never had a problem.
Old Feb 16, 2004 | 03:44 AM
jkipp84's Avatar
Correct.
I use the Holley CAI and some 2" holes drilled in the bottom plastic part by the ground. With the hood shut, the filter is isolated from engine heat. It may not be as optimal as the Moroso/K&N/etc, but it seems to be doing the job very well.
I'd have to go through water high enough to submerge the wheels before the filter sees it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
Britbilly
Jan 7, 2015 08:49 PM
squirrels
Jul 13, 2002 01:58 AM
