coil replacement question
hey all replacing the coil for my car. i have the de-electric grease, but it says i should also use some heat transfer grease on it as well. what kind can I use? the regular stuff from radio shack??
on a side note, i was surprised to see the local autozone had the german made castrol 0w-30. |
The RS stuff should be fine.
thanks shoebox, I replaced it. wasnt hard, except the hole from where i tapped out the rivet was too small for the screw that came with the new coil, but fixed easily with a visit from mr. drill. then had a battle with the intake elbow as it didnt want to go back into place over the tb. I punched it a couple times and got mad and man handled it back into place. took it for a test drive, got a ticket for no front plate and Im home. lol
| All times are GMT -5. The time now is 07:36 AM. |
