coil?
Old Apr 14, 2003 | 10:44 PM
speed76demon's Avatar
Arrow coil?
Could a bad coil cause this.. In the morning my car starts up fine but if i drive it for awhile meaning over half an hour then let it sit for half an our or so and i go to start it it will first start then start to gag and stutter start ideling rough then it will die then i try to start and have to mess with the gas a little but if it starts then i touch the gas pedal it doesnt seem to help only hurt. Also if i shut if off it will start right back up if i do it right after i shut it off or is this problem just the 02 sensors??
Old Apr 15, 2003 | 12:31 AM
cef97ws6's Avatar
I may be out in left field here but I would be concerned more with fuel pressure. If you have the means to check fuel pressure I would look at that first. Also check the integrity of the fpr possibly failing diaphram. Let us know.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Z Power
Sep 19, 2015 11:19 PM
