Code =P0420?
I keep getting this code. My manual says it means "cata
P0420 = Three Way Catalytic Converter (TWC) system low efficiency Bank 1
It means the cat on the left side of the car is clogged or some crap! Actually I think it means that you should have bought an OBD1 Car :D |
Would that be the "coffee can"? when I looked underneath, it appeared to have only 1 cat, right after the Y.
Yes it is the can looking thing after the y. '96 is a duel cat car so the other one is in the vertical position next to the oil pan. I think this is the one you are having problems with as I think the driver side is bank one.
Bank 1 is drivers side. I wasnt sure if that "thing" was a cat or not. Makes sense now. If I get rid of 1, should i do both? cant really afford to since i'm married w/ 4 children and am the only 1 working. Is there any negative effect from removing just 1?
If you remove them you will have to get O2 sims or the SES light will stay on.
| All times are GMT -5. The time now is 06:53 AM. |
