CamaroZ28.Com Message Board
-   -   Chewed Wires (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/chewed-wires-540563/)
IXLR894Z28 Aug 30, 2007 10:28 AM
Chewed Wires
I have a friend with a 97 Z28 that has been parked for a few months. While the car was parked, a few little rodents chewewd through the injector wires on the passenger side. Is there an easy replacement, or does he need a new harness?
Sparkz28ss Aug 30, 2007 10:59 AM
can he solder wire well...go to radioshack and get some solder stuff...
soldering iron
flux
solder - get good solder
heat shrink.... go at it.. you could have it fixed in no time.. and its a good skill to have and work on...
or you can buy a used injector harness...I have one sitting around some place
Vicious95Z28 Aug 30, 2007 11:38 AM
soldering iron
flux
Yeah, unless you're an epileptic!
IXLR894Z28 Aug 30, 2007 12:38 PM
I guess they are chewed right at the top of the injector, is there a way to get the wire out of the connector, or can he get new connectors?
sandman2100 Aug 30, 2007 03:17 PM
http://www.eficonnection.com/
