Changing gas pump
How hard is it to change the fuel pump?? Any other info on this subject will help too
Probably not too hard, though you should get the permission of the gas station first.
Oh, do you mean the fuel pump? :) It's either a real pain in the ass, or expensive. You need to drop the rear end, and then the tank. I'm hoping my pump never goes out on me. If it does I'll probably just part out the car. :D |
Originally posted by Ace_437 Probably not too hard, though you should get the permission of the gas station first. Oh, do you mean the fuel pump? :) It's either a real pain in the ass, or expensive. You need to drop the rear end, and then the tank. I'm hoping my pump never goes out on me. If it does I'll probably just part out the car. :D jesse |
Originally posted by QCKZ28 acces panel method and swapped to a walbro 255lph in about 3-4 hours VERY EASY jesse |
you guys knowof any sites with a more detail explanation on how to do it?
I did the drop the tank method. It took me around 2 hours total time. I had never done it before either. I lost the link to the guide i used. It was steve somebodies, but do a fuel pump install guide search on here and u will find several. I got mine off of here. If u have any questions just ask. -Michael
| All times are GMT -5. The time now is 09:20 AM. |
