Changing Cam,need info
Old Nov 15, 2003 | 07:34 PM
lvega's Avatar
Im plan on putting in a CC306 in my 94 Z,car has all the accessories including AC, what kind of problems will i run into,will the cam come out without pulling the Condensor?
Old Nov 15, 2003 | 07:57 PM
FastZinTennessee's Avatar
You'll need to replace the timing chain. I'll let someone else recommend one because I'm on the stocker, which I wouldn't recommend for you unless you are using an electric waterpump(less stress on the chain). You will be able to get the cam out with the condensor in it. Remove the radiator, you may have to rotate the condensor a little, but you can squeeze the cam out. You'll probably have to pull the intake manifold so you can remove the lifters. When removing the timing chain, it's helpful to loosen the oil pan and drop it down, the oil pan gasket forms the bottom gasket for the timing chain in front. If you try to pull the timing chain cover with the oil pan still in place, you will rip the gasket. You also run the risk of messing up the seals that go around the crank snout, opti drive and water pump drive. It's best to drop the pan enough to clear and pull the timing cover straight off.
Old Nov 15, 2003 | 08:51 PM
If you want to read up on what is involved, there is info on my Tech Page and here are a couple of other sites:
http://www.afrashteh.com/guide/install.htm
http://www.streetillusionsracing.com...ll/install.htm
Old Nov 15, 2003 | 09:36 PM
lvega's Avatar
Thanks for the very informative info,STREET ILLUSIONS website is very impressive,great pictures & step by step info,i will definintely use the info for cam & header installs
CJ
Old Nov 15, 2003 | 09:58 PM
CJ
Gee, I hoped you would find my page useful.
Old Nov 15, 2003 | 10:30 PM
lvega's Avatar
Rob,i just checked out your Tech Page,very,very detailed as well,all i can say is im very happy i found this website,i think i will keep my 396 Camaro Z now that i have all these technical websites to help me out.
blac94Z
Feb 18, 2015 11:36 AM
birdblack
Dec 30, 2014 06:59 PM
30thZ4C
Dec 26, 2014 05:09 PM
Queens94z28
Nov 20, 2014 06:03 PM
