ceramic coating on headers?
I ran into a friend of mine I have not seen in a couple of months and was talking to him about get my SLP headers ceramic coated.
He told me that they would be fine till you get water splashed on them the the coating will crack and come off. Can this be True? Has anybody had this problem? Thanks, Chris G. |
Re: ceramic coating on headers?
your friend is a moron......i have ceramic coated long tubes, and they have seen water w/ minimal defects (some surface rust) only because ive scrapped leaving steep hills which took the coating off ;)
Over time, the coating WILL discolor and start to peel crack. I have had JET-Hot, and whatever Pacesetter uses, and they both perform the same.
They will look great from the top, but on the bottom they will peel. I still say the coating is a must on 4thgens. |
Well Do you think I need the coat the SLP shortes?
They are stainless steel so rust won't be a problem. I was thinking of getting them coated pretty much so I don't get more heat under the hood. What do these headers look after a couple of years on the car do they change colour? I would love to put these things on now that I have time but if they are going to put more heat in the engine bay then maybe I should Waite till I can get them coated. What do you think? Thanks, Chris G. |
They will look great from the top, but on the bottom they will peel. |
If there ever were a header that you could get away with not coating it is the SLPs. But coating them will help everything near 'em in terms of heat. Also, with those expensive SLPs you might wanna protect the investment.
Jet Hot has a 3 year warranty on the coatings. I sent mine back to Jet Hot after about 5 years and they recoated the headers and Y pipe for half price, $114. They still looked good when I sent them but just wanted a new coating. The Y pipe was scraped up and the coating falling off but the headers were just a little discolored.
Stainless don't need coating. Yes the stainless will shed it's coating in a year or two,it just can't stick to the stainless like mild steel.
I'm running these headers and I bought them used for to $240. They are coated and are in great condition (no peeling). These run really close to the heater box. It would be a HUGE mistake, if you didn't get these headers coated. You will also need to buy the heat shield from slp. it is only $20. They are easy to install but taking off the stockers was a pain.
The purpose of coating the headers is to reduce the underhood temperatures. And in two years you want them recoated you just send them to Jet-Hot, all you pay for is shipping. I think coating headers is a must on any vehicle.
I was running the SLP shorty headers, ceramic coated, and i could a swore they looked almost chrome when i first put them on. Over time, a couple years later, they turned into a grayish color. Also there were some brown spots throughout the header which i think was due to something burning on the headers. I think LT1's run pretty damn hot and would be smart to run the headers coated in my opinion. Also when i puchased my headers thats what SLP told me as well. Could have told me this to make a few extra dollars, i dont know. To add on to that, look at headers that were not ceramic coated, god there ugly lol. -Matt
Well it looks like I have to bite the bullet and wait till I get a JOB and have them coated.
How does that fire sleeve work on the AC in the corner? IE how does it go on? If any body knows about the fire sleeve let me know. :) Thanks for all the input. :thumb: Chris G. |
I use 3M spray on glue and put on the ac box and the blanket. I also use some aluminum flu tape.
