95 LT1 Fuel problem?
Old 09-14-2018, 10:25 AM
Treggk123's Avatar
Alright just bought the car a few weeks ago and replaced the coil, I'm, and starter. It seems like every time I get gas my car doesn't wanna start for awhile after. I can hear the fuel pump. But it just cranks and won't turn over. Gotta wait a few mins every time my car turns off.
Treggk123 is offline
Old 09-14-2018, 10:30 AM
Chimera96's Avatar
Re: 95 LT1 Fuel problem?
have you checked what your FP is?
Chimera96 is offline
Old 09-14-2018, 10:33 AM
Treggk123's Avatar
Not yet was running good all week until I just got gas again. Just bought a test kit. I'll check what it is after work
Old 09-14-2018, 11:20 AM
Treggk123's Avatar
I can get it started by pressing the pedal while cranking
Old 09-14-2018, 01:49 PM
Holding the pedal on the floor while cranking puts the PCM in “clear flood” mode.
Injuneer is offline
Old 09-14-2018, 04:10 PM
Treggk123's Avatar
Is that a problem? Sorry just starting to learn about this car
Old 09-14-2018, 05:24 PM
If it starts quicker with the pedal on the floor, it may be indicating the engine is flooded.... example - leaking injectors. But the question remains why only on a new tank of gas? Do you tend to overfill the tank? That can cause problems with the carbon-filled fuel tank vapor collection system.
Checking the fuel pressure would be a good first step, as noted in an earlier post. Turn key to “run” (not “start”). Watch gauge to note peak fuel pressure when the pump stops priming (after about 2 seconds pump run time). Should be at least 40 PSI. Then watch to see how fast the pressure drops. Rapid pressure drop can cause extended cranking time.
Injuneer is offline
Old 09-15-2018, 11:43 AM
Treggk123's Avatar
Pressure was 43 and dropped to zero after a few secs. Its starting up today without having to press the gas. just rough
Old 09-15-2018, 12:55 PM
The pressure should hold, or drop slowly. Causes of rapid pressure loss:
1 - leaking check valve in fuel pump
2 - leaking injectors
3 - leaking fuel pressure regulator diaphragm
4 ​- fuel pressure regulator not closing off fully, allowing pressure to bleed off into return line
5 - leaks in fuel supply line, including flex pipe in tank
To check #2, pull rails up with injectors intact. Key to “run” to pressure fuel system, look for drips.
To check #3, look for wet fuel in the vacuum compensation line to the fuel pressure regulator.
#1, #4, #5 harder to diagnose. But #2 and #3 could cause a flooded condition.
Injuneer is offline
Old 09-19-2018, 07:51 AM
Oval2Bowtie80's Avatar
Yeah it's one of those, my canisters totaly shot and even when you top it off the most that will happen is a check engine light but it doesn't effect anything else.
Oval2Bowtie80 is offline
Old 09-19-2018, 08:16 AM
What code sets when you “top it off”? That would seem like a critical piece of information as to the cause of the problem.
Injuneer is offline
Old 09-19-2018, 08:23 AM
P1441 evap emission system flow during non purge. I deleted it and stopped topping off till I get a canister installed and haven't had the issue except for smelling fuel.
Old 09-19-2018, 08:25 AM
I was basically dumping gas into the solenoid
16Sammy61
07-14-2014 10:29 PM
hysteria1
03-27-2007 08:51 AM
deftoned95Z28
04-01-2005 09:07 PM
Camaro91RS
3rd Gen / L98 Engine Tech
09-21-2004 02:17 PM
jeff94z28
03-01-2003 11:43 PM
Quick Reply: 95 LT1 Fuel problem?
