97 Z28 Wiring Harness
Old 09-18-2018, 04:26 PM
weedog's Avatar
Does Any One Know Where I Can Have My Wiring Harness Repaired Or Find A Good Used One Field Rats Chewed Up About 12 Or 14 Wires On Mine Where On Of The Big Plugins Goes Top The PCM Board. Car Has Been Sitting In Garage Since 2011 When It Was Run Hot And Blew A Head Gasket. Going To Try To Post A Picture Of The Wiring Harness.Thanks
weedog is offline
Old 09-18-2018, 06:12 PM
Re: 97 Z28 Wiring Harness
In reply screen, click on “Go Advanced” button at the bottom. In next screen, click on “Manage Attachments”
If starting a new thread, should see “Manage Attachments” right below message field.
PS: if you post with the caps lock on, you end up with the first letter of each word capitalized, as in your post above.
Injuneer is offline
Old 09-18-2018, 08:24 PM
weedog's Avatar
I tried what is in your post and It want send the picture
weedog is offline
Old 09-18-2018, 09:47 PM
weedog's Avatar
weedog is offline
Old 09-18-2018, 09:50 PM
weedog's Avatar
as you can see the rest of the wiring harness is in good shape
weedog is offline
Old 09-19-2018, 05:02 PM
What exactly are we looking at in the closeup of what you seem to have described as a damaged area? Looks like a bunch of splices have repaired the damage. Not sure I understand. Is that something you did, or is that what you found when you opened up the plastic wire loom?
Injuneer is offline
Old 09-19-2018, 08:06 PM
weedog's Avatar
A guy at a shop did it for me about 3 or 4 years ago and sometimes the driver window want go up and some other problems I have that was not there before the rats chewed the wires up. A guy on e bay has a wiring harness that I think will work with no damage for 299.00 with free shipping. Would that be a good way to go since I have the motor and all out of the car. I think the one on e bay will work. Thanks
weedog is offline
Old 09-19-2018, 08:26 PM
You would have to compare the problems you experience with what is wired through the BLACK connector. In particular, the power windows have nothing to do with the PCM. Power window problems would be due to the window motor, the switch, the body harness or the BCM, not the engine harness.
Shoebox has a pinout chart for the BLACK connector - things like A/C, distributor ignition, PCM power supply and transmission plus a few other items. Look over the table and see if any of the items wired to the BLACK connector are things you are having problems with:
http://shbox.com/1/1995_pcm_conn_b.jpg
Is the eBay harness out of a 96/97 ?
Injuneer is offline
Old 09-20-2018, 08:32 AM
weedog's Avatar
Its out of a 96
weedog is offline
Greg88
03-17-2019 02:33 AM
flusz28
08-24-2004 12:58 PM
94redz6sp
05-16-2004 10:05 PM
Wolf Warrior
03-28-2003 12:44 PM
Quick Reply: 97 Z28 Wiring Harness
