CC306 Spec
That info I have is
290/307 0.510/0.540 112
230/244 @0.050
Valve opening @0.050
Intake 7/43
Exhaust 58/6
And the this I want is something like this
Cam Spec Card Inquiry
PART NO. 08-301-8
01 INTAKE MASTER 3314S
02 EXHAUST MASTER 3316S
03 ENGINE CS NR276HR-113
04 GRIND NUMBER CS NR276HR-113
05 HYDRAULIC Y/N YES
06 VALVE ADJUSTMENT HYD
07 MAX GROSS VALVE LIFT .502 .520
08 DUR @ .006 TAPPET LIFT 276 288
09 VALVE TIMING @ .006 OPEN CLOSE
10 INT 30 66
11 EXH 82 26
12 THESE SPECS ARE FOR CAM(S) INSTALLED @ 108.0 INTAKE CENTERLINE
14 DUR @.050 224 236
15 LOBE LIFT .3350 .3470
17 LOBE SEPARATI 113.0
18 ADVANCE 5
19 VALVE SPRINGS 986-16
230/244 @0.050
Intake 7/43
Exhaust 58/6
PART NO. 08-301-8
10 INT 30 66
11 EXH 82 26
18 ADVANCE 5
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 09:20 AM
