CamaroZ28.Com Message Board
-   -   Carbed Lt1 Conversion ???????'s (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/carbed-lt1-conversion-s-534765/)
jammer94 Jul 29, 2007 09:49 AM
i am doing a carbed setup i got now and the motor is in car with a non computer controlled CAM it has a SBC stlye damper on it now, so how do i adjust timing where does the timing tab goes also on the LT1 will i have a 3rd gen which had a TPI motor will i be able to mount the old stlye accesorries on to the LT1 block will it bolt up or will i have to use the lt1 accesorries and bracket...????
please anyone with some info on this would be greatly apprecaited.
chevyowner02 Jul 29, 2007 11:17 AM
I dont know about the carb set up but accesorries you will need to use the ones on the LT1. As I read on another board " thats alot of maze for alittle cheese"
jammer94 Jul 30, 2007 08:47 AM
ttt
