Carbed Lt1 Conversion ???????'s
i am doing a carbed setup i got now and the motor is in car with a non computer controlled CAM it has a SBC stlye damper on it now, so how do i adjust timing where does the timing tab goes also on the LT1 will i have a 3rd gen which had a TPI motor will i be able to mount the old stlye accesorries on to the LT1 block will it bolt up or will i have to use the lt1 accesorries and bracket...????
please anyone with some info on this would be greatly apprecaited.
