CamaroZ28.Com Message Board
-   -   Carb on lt1 (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/carb-lt1-352062/)
Ripcurl3249 Mar 23, 2005 06:32 PM
Carb on lt1
do they make an intake manifold for 96 lt1 and how does the setup fit under the hood.
1quikZ Mar 23, 2005 07:18 PM
Re: Carb on lt1
yes, gm performance makes it, and it does fit under the stock hood
RacinZ Mar 23, 2005 08:01 PM
Re: Carb on lt1
Just remember the opti spark will no longer work. Is it going in a F body (93> then you will need to make room for the distributor to work.
